TwinTurbo.NET: Nissan 300ZX forum - Re: the defi is tapped in between the cluster and the ECU?
Carlos Ramirez
on November 14, 2012 at 12:17 PM
posted by aliaZ
on November 14, 2012 at 12:11 PM
I was going to check at the ecu first and remove and VSS taps and do a continuinity check as well. Just was kind of hoping to hear yeah "I had that problem before and the cause was etc and the fix was etc".
Thanks for you feedback.
ECU not seeing Vehicle Speed
Carlos Ramirez
11:12:27 11/14/12
aliaZ
12:11:42 11/14/12
Re: the defi is tapped in between the cluster and the ECU? -
Carlos Ramirez
12:17:52 11/14/12
If you replaced the efi harness and de-pinned the connector
ShakaShaun(Denver)
18:06:35 11/15/12
Same here, easy to do. (n/m)
Fast300
15:36:07 11/17/12
